ktmrfs
Jun 25, 2019Explorer III
most radios have two power sources. One is a switched power for the normal on/off the other is unswitched power to retain memory. Are you sure you didn't get the wires switched?
BTW as a side note most trailer radios are the same and will slowly drain the battery even in the off position since they draw enough power in "standby" to drain a single 12V battery in a few weeks.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
