Woodtroll's avatar
Woodtroll
Replacement Seals/O-rings for Portable Propane Cylinders?
Hello, folks, I have a 30-lb. propane cylinder that has a bad gasket/O-ring that is causing a leak. This is the seal that the nose of the fitting presses into and seals against. (It is the newer O...
