somatronicon
Sep 13, 2017Explorer
robatthelake wrote:
I know someone will flame me for this suggestion but!
Those solenoid used replaceable coils ....well back in the late 80'S they were pretty common. Anyway they are relatively easy to take apart. Once apart if you ever took a close look you will find that the coils are fine copper wire and if you check the resistance ..well just start unwinding the wire until you find where it has broken. If you are lucky it will be in the first couple of feet,maybe five!
Try applying 12 volts to see if it works without the removed wire!
This doesn't always work ,but it did for me about ten years ago and that old water heater is still working today!
Interesting! I like your resourcefulness :D This is more my speed actually. I already have a part coming that someone else suggested, but I may give this a shot with the old one that no longer works to see if it's a viable solution in the future.
I wonder if newer valves can still have the coil removed... That'd be interesting to see.
Thanks for the great suggestion robatthelake!
Christopher
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
