I will be replacing my 30amp TT cable. Other than making sure the power is off and wires connected correctly is there anything else I should be aware of? Thanks-don't want to toast or roast.
If your cable is permanently attached to the RV, check that the strain relief at the RV end is up to snuff. You don't want to pull the cable out and have it put strain on the connections to the transfer switch or whatever it connects to.
