vandaveExplorerMay 18, 2016Replacing 30 amp cable.I will be replacing my 30amp TT cable. Other than making sure the power is off and wires connected correctly is there anything else I should be aware of? Thanks-don't want to toast or roast.
wa8yxmExplorer IIIMay 19, 2016If you are talking about the shore cord.. Make sure you are unpluggedIf you are talking the line TO the shore outlet... Well, there is a bunch of stuff depending on how the wire runs.. But I'll let others cover that.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 11, 2026
Related Content80 amp converter and eu2000iBreakaway cable replacementConnecting two 50 amp service cables together?30 Amp VS 50 AmpReplacing Cable Waste Valves
