urbex
Mar 19, 2017Explorer
Replacing ancient Suburban water heater with new?
So I'm pretty sure I just caused terminal damage to my water heater...
I have a 1974 Amerigo truck camper, with a Suburban G 602, 5.7 gallon water heater. I attempted to drain/flush it, and got nary a drop when I opened the drain, but did get some water out of the safety valve on top when I opened it (water heater hasn't ever been on since I bought the camper last summer, so it wasn't hot).
I figured it was just clogged with crud, so I took a socket to the drain valve to get it off and clean it....and promptly snapped it off the drain pipe...oops. The drain pipe is also packed full of calcified stuff, so I figure it's likely safe to assume there's plenty more in the tank as well, and previous owners likely didn't maintain it well.
That said, are these things fairly standard in size? As in if I get a new Suburban 6 gallon model, it should drop in the same size hole? Or are they like the refridgerators where there are a million different sizes, and I need a specific model to retrofit this old stuff?
