MaestroPNW's avatar
MaestroPNW
Replacing DPDT slide out switch with reversing type?
The slide out switch in my Arctic Fox TC has gone bad.
I got a new one, but it's a different type.
The old one is a standard DPDT, with power and ground connected to the center and motor leads are connected to sides in criss-cross manner. In neutral position, motor leads are not connected to anything.
The new switch is the reversing type. I can rewire the harness, but the main difference would be that BOTH motor leads are grounded in neutral position with the new reversing switch.
If they went straight to motor, it would be no problem, but I'm not sure what's in between - there's some limit switches circuitry at least, and there is no detailed electrical diagram in the papers.
Should it be ok to replace the switch?
Thanks!
  • Reliving the nightmare there! :( Note the part about trial and error with the last two wires to the motor for which is IN and OUT BEFORE you shove it all into the hole in the wall and screw the switch on.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
