NanciL's avatar
NanciL
Explorer II
Jan 06, 2016
Replacing handle on my Awning strut
I broke the little pin on the awning strut lift handle and need to install a new handle.
It is riveted .
Has anyone replaced one, and if you did, can you rivet it with out taking the strut apart from the roller ?
Jack L
  • Part comes with pop rivet 3/16 very easy repair as long as you have a pop rivet gun drill and drill bit.
  • Can you use a bolt with a nylon core nut instead? If you want to get fancy, you can use stainless steel.
  • I went to an rv place and got one off a junked awning for a buck. An easy fix with a pop rivet gun.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
