Pangaea_Ron
Nov 01, 2013Explorer
I was actually able to have my MW repaired, which is very unusual now. There were 3-4 thermal/power fuses that needed to be replaced. Mine was built-in with range hood and convection functions. It took nearly 45 minutes to remove, and about the same to re-install.
Could you mount a metal J-molding on the wall behind, and an inverted J-molding on the MW that would interlock, and/or mount pipe end caps on the bottom of the cabinet that the rubber feet could fit into. My MW also had sheet metal screws through the top of the cabinet above into the metal case of the MW. Perhaps you could also do the same from the sides? Be careful where you drill.
Common wisdom in an accident is to lift your feet up when the accident happens, and then duck when the MW comes forward. Timing is everything.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
