SFVdave's avatar
SFVdave
Replacing microwave, model no longer made
Last weekend, our microwave stopped heating. It is a 10 year old Samsung 1cuft no longer produced. I took it into a repair shop on Monday for a free estimate, where it sat until yesterday. I went into the shop and the tech said they usually aren't worth the cost of fixing. So I took it home. Who knows when he would finally get to it.
In the mean time, I ordered a new slightly smaller .9cuft that would fit into the existing microwave cabinet just in case it was not repairable. This is where it gets complicated. My Winnebago Minnie has the kitchen against the back wall. The microwave cabinet is at an angle and faces forward. So the microwave has to be secured well to prevent a panic stop from ripping it out of the cabinet. The previous microwave utilizes 2 braces attached to the back wall and secured to the facia of the cabinet. The trim cover is screwed into the braces at the facia. A large "L" shaped bracket is attached to the wall and to the cabinet facia for the top trim piece to attach to. Of course the new microwave trim grill has holes that nowhere match up to the existing holes. Plus the new trim grill doesn't even go down low enough to cover the exist holes. The trim grill itself came with 4 small screws to attach the trim grill to the cabinet facia. These screws would never hold the microwave securely. I thought about using a hard wood like oak and glueing blocks where the new trim grill screws can attach in back of the facia. I would of course use longer screws to attach the trim grill to the facia and oak blocks behind. But now I wonder if that would hold up in a panic stop ripping the microwave off along with the facia.
The microwave cabinet is above the stovetop and next to another cabinet. Access to the back of the microwave when install is very limited. There is a 2" hole for the microwave's power cord to pass thru. I thought about using a cable or something attaching it to the back of the microwave and the brace attached the the wall. But I have no access.
Suggestions?
  • Before you do anything else. Remove screws that keep the cover on the top of the microwave and lift the cover off. most microwaves have a standard fuse mounted in there somewhere. Might be a simple fix.
  • if you can get to the bottom? unscrew the rubber feet and install a longer screw.
  • Many different ways to do a project like that. Just use your own judgement and mechanical abilities. If you lack them, have a shop do it.
    If it was me, i'd make sure the micro works good, than as cheap as they are, ignore any thoughts of warranty, and drill some mounting holes in the micro case,..... if all else fails.
  • I'm not very good at trying to visualize according to your description, but it seems that you might be able to rig a steel bar on either side of the micro attached to something secure in the back of the cabinet or to the wall, and fab a removable bar that goes in front of the microwave hooked to the side bars when traveling and stows in a drawer when parked.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
