RJsfishin
Mar 09, 2016Explorer
It doesn't have to be messy.
if there is no drain plug, just reach under and drill a 3/16 hole in the rear corner of the pan, and let'er drain overnite.
By next day there is very little drippage when removing the pan.
Clean up the pan, drill the hole out to 1/2", and weld a 1/2" fine thread jam nut inside over the hole, and use a 1/2 x 3/4 bolt w/ fiber washer for the plug. Or if no welder, buy a drain plug kit from Napa.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
