BigWapitiExplorerJul 23, 2020Replacing PD 9145AI need to replace my power converter (PD 9145A). Since I'm needing to replace it - should I replace it with the same make/model unit or are there better options that I should go with instead?Show More
LwiddisNavigatorJul 23, 2020Generally and “nowadays” no electronic device should be replaced with the exact same model.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
Related ContentReplaced WFCO with PDReplacement Lights for TTPD Vs. WFCOPD Power Transfer Switch ReplacementReplace insulation inside heater column.
