I need to replace my power converter (PD 9145A). Since I'm needing to replace it - should I replace it with the same make/model unit or are there better options that I should go with instead?
If you are planing on installing an inverter in the near future, consider buying an inverter/charge/automatic transfer switch.
Remove your current converter and wire the DC distribution panel directly to the battery. Wire the inverter/charge/automatic transfer switch directly to the battery. Wire the exterior shore power inlet to the inverter and the AC output of the inverter to the AC breaker panel. DONE !
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
