BigWapitiExplorerJul 23, 2020Replacing PD 9145AI need to replace my power converter (PD 9145A). Since I'm needing to replace it - should I replace it with the same make/model unit or are there better options that I should go with instead?Show More
pianotunaNomad IIIJul 23, 2020What happened to the one you have? You may want to upgrade a bit, depending on your answer.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
Related ContentReplaced WFCO with PDReplacement Lights for TTPD Vs. WFCOPD Power Transfer Switch ReplacementReplace insulation inside heater column.
