I need to replace my power converter (PD 9145A). Since I'm needing to replace it - should I replace it with the same make/model unit or are there better options that I should go with instead?
Your AGM and any flooded too needs to see 14.x volts to be charged up properly. Your converter without the Charge Wizard only does 13.6v, so your battery will die an early death.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
