BigWapitiExplorerJul 23, 2020Replacing PD 9145AI need to replace my power converter (PD 9145A). Since I'm needing to replace it - should I replace it with the same make/model unit or are there better options that I should go with instead?Show More
enblethenNomadJul 23, 2020you can get a Charge WizardIt plugs into a PD 9100 series using an RJ-45 connector. It looks like a ethernet plug.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
Related ContentReplaced WFCO with PDReplacement Lights for TTPD Vs. WFCOPD Power Transfer Switch ReplacementReplace insulation inside heater column.
