MrWizard
Sep 19, 2016Moderator
i'm sorry, this seems like a lot of work for nothing
do these switches need to be lighted, when the water pump etc is NOT on
changing the switch and going to all electronic control, will not alter the amount of power the pump uses
IF you really have the physical need to use membrane switches for water pump etc
how do you manage to do all the things you do now ?
is this the case of needing 'a reality check' ?
if current switches are worn out, replace with something that use an LED for lighting the switch, so you know its on
