MEXICOWANDERER
Sep 21, 2016Explorer
Tis entirely indeed a issue of wet bulb (ugh) dry bulb (yay) corrosion.
Condensation precipitates salt out of solution. So if dew does not accumulate it can DO no damage. This is why I allow the bus to heat up during the day. Cruising sailboat owners thought I was nuts mounting alternator voltage regulators a foot distant from water cooled exhaust jackets. But diesels have a habit of emitting a fine oil vapor and plus the heat, it keeps terminal boards shiny. That and mounting the regulator like I did on Quicksilver, on a square 12" piece of 1/4" aluminum plate using silver heat sink mounting paste. The plate sucks heat from the regulator like you cannot believe.
