Treadwheeler
Feb 17, 2015Explorer
Replacing water pump
I have to replace my water pump - apparently didn't get it drained fully when winterizing. There was ice in inlet and outlet side when I went to work on it this this past weekend. Ran hot water through to thaw out, hooked it back up and pump will not stop running - with all faucets off and no leaks anywhere I can find. Thinking the diaphragm may be damaged or an airleak somewhere.
All said, we will be out of town for the next two weeks and following week need to use the RV so I will just order a new pump to have and replace when we arrive at destination if need be. I looked at both the Flojet and Shurflo models and like what I read about the Shurflo best.
Question is what about the Artis Power Drive model? That is the pump that came with the RV and has worked well to our satisfaction.
Is the Shurflo just a better pump?
Has anyone had any trouble with the OE Artis Power Drive pump as either OE or replacement?
Had I done a better job winterizing - I would not be looking to replace the Artis OE we currently have.
Both the Shurflo 4008-101-E65 3.0 Revolution & the ARTIS 3.0 GPM - PDS1RV25 Series 1 models are comparably price
