BFL13
May 23, 2017Explorer II
This is what we use for everything. It is MSW, but nothing we have needs PSW. Grab it fast before the price goes back up. These things go on sale a few times a year but hard to predict when. Same with the 2000, which would also work.
http://www.canadiantire.ca/en/pdp/motomaster-eliminator-mobile-power-inverter-3000w-0111846p.html#srp
If you have something that needs PSW that is low power you can get a second, smaller PSW inverter just for that. Way cheaper total than a monster PSW.
A 100amp charger with adjustable voltage can be had for not much money too. Is it to also be your converter or can you go 100 amp charger plus a ? amp converter? Important--what generator do you run the 100 amp charger with? (Decides whether you need the charger to be PF corrected or not)
