mena661
Oct 11, 2013Explorer
smkettner wrote:Yep! Don't need all that******with Li. Add not needing to keep them at 100% charged either. And throw away your float chargers. Not required. It's recommended to STOP charging once they're fully charged. You could come home from a trip and leave them in a discharged state and charge them up before the next trip. They do self discharge so you don't want to drain them to flat dead cause they'll be flat dead, non-recoverable. Good news is self discharge is equal to AGMs or better.
No "50% rule" with Li-Ion. And they prefer starage at ~50%.
They charge so fast they may even get WFCO into boost mode ;)
And just like old typewriter ribbon, the equalization/reconditioning will be obsolete.
With any luck RV chassis will go hybrid and you will have 1,000s of amp hours for boondocking.
BFL13 wrote:No Li's BFL!!! There's enough data out there that confirms that this is all true. Head over to the DIY Electric car forums, TONS of info on Li batteries in real world usage there. There and the sailing forums is where I got all my Li info from.
Must be the "Big Li" Tell it often enough and----
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
