Almot wrote:
Roadpilot: without a very substantial solar it will take another 1.5-2.5 generator hours a day - in addition to whatever it takes to meet your regular energy needs - to power a residential fridge. If this is not a problem, then there is no problem :)
I do have a problem with people running a genny all day long when it's not so hot that A/C is needed, and trying to avoid such camps. Mostly they run a genny not because have a residential fridge. Just a poor energy management or not enough knowledge, often small batteries.
For camping with hookups and traveling less than 5-6 hours in between there is no problem with residential fridge.
I think MrWizard found that did NOT require more than 1/2 hr to 1 hr of charging per day when he changed to a residential fridge. He is also using the same inverter that I am using although I do not know if he is using the power save feature.
He has added some extra solar and perhaps a little extra battery capacity some time after his change. If I remember correctly he actually is able to use the gen LESS.
People tend to forget that modern day RV fridges USE 12V to run the control board and gas valve. This actually makes the change over to residential fridge even less of a big deal..
I am sure someone will have some data but I would hazard a guess that the control board and gas valve would use 5Ahr to maybe 10 Ahr PER DAY.
In my case, my fridge runs 20 minutes per hr, draws 90W (.75A) (actual measured) at 120V running. So that is 7.5A at 12V plus the inverter lose of 1.5A gives me 9A at 12V. This gives me 3Ahr of usage PER hr, over 24hr period that comes out to 72 Ahr used.
Now if I subtract 10Ahr that the RV fridge WOULD have used in 24hr I would now have 62Ahr additional used.
My pair of GC batts give me 210Ahr capacity and usable of 105 Ahr, subtracting 62Ahr gives me 43Ahr left over for furnace and lights for a 24hr time period.
If you are concerned about running a gen longer then adding in 130W of solar and perhaps an extra pair of GC batts would REDUCE the gen time to less than what you would with a RV fridge.
