Cstoliker's avatar
Cstoliker
Reverse lights only work with parking/headlights on
98 Ford E Super duty Tioga. Inspection time I was checking the lights an noticed the reverse lights only come on when parking/headlights are on.
I re wired all the parking lights a while ago. The reverse lights have good ground 00.2-3 ohm from out side of bulb to frame. So it's not pulling the ground through a parking light bulb.
All other lights work normally. The reverse lights only get +12v at the socket when the transition is in reverse and the parking lights are on.
Is there something in the steering column that could be casing this?
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
