RoyB
Oct 14, 2015Explorer III
REVERSE POLARITY on the 12VDC BATTERY setup has fuses to protect against things like this. The REVERSE POLARITY FUSEs betwen the battery terminals and the 12VDC distribution panel will immediately blow if the battery terminals are reversed accidentally..
Am not familiar with the panel you are referring to but it sounds like it is referring to REVERSE POLARITY on the 120VAC side of things... i.e. the three 120VAC conductors (HOT-NEUTRAL-GROUND) coming from the shore power cable side are seeing this problem and reporting at such...
I would use one of those 120VAC circuit tester plugged directly into a 120VAC receptacle and see what lights show on it...
If every thing is wired correctly only the two ORANGE LIGHTS on the bottom right will be lit up...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
