RoyB
Oct 14, 2015Explorer III
The campground/park should be wired up like this...
You can measure the three legs on the 30AMP side with a standard mulitmeter and should duplicate these readings. If not then the campground/park has a problem.
50 AMP SIDE
30AMP/20AMP SIDE
Use this pictorial on which wires go to which pins in the plugs...
Most definitely not a good idea to change your PLUG to match up with a miswired or campground/park problem. Then you will have problems when you go somewhere else... Make them fix their problem...
All of this info is available from GOOGLE SEARCH
Roy Ken
50 AMP SIDE
30AMP/20AMP SIDE
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
