CA_Traveler
Oct 14, 2015Explorer III
Chris Bryant wrote:True reverse polarity doesn't happen unless some wires are connected wrong.
it's just a light hooked between neutral and ground.
But that light could come on due to bad connections cause abnormal voltage drop on one of the wires - that is enough voltage for the light to work.
For starters have the battery load tested at a auto store. Get the AC plug replaced, the reverse polarity light is off, make sure the battery is being charged and perhaps the radio will work.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
