Bobbo
Sep 28, 2020Explorer III
time2roll wrote:
You can verify or just fix it.
Turn off power at the breaker, remove the connector, reverse the Hot and Neutral, replace connector, restore power.
http://www.myrv.us/electric/Pg/30amp_Service.htm
Before I switched the wires, I would want to confirm that it is, indeed, the outlet that is mis-wired. Hence my recommendation for the no contact voltage tester. If he re-wires the outlet, but it was actually the EMS that was wired backwards, he has not helped himself.
