time2roll
Sep 29, 2020Nomad
Bobbo wrote:Since the EMS appears to be portable I assume the premade connectors are wired correct.
Before I switched the wires, I would want to confirm that it is, indeed, the outlet that is mis-wired. Hence my recommendation for the no contact voltage tester. If he re-wires the outlet, but it was actually the EMS that was wired backwards, he has not helped himself.
If EMS was hardwired version done by the RV owner I would have more concern.
Either way the pictures show the correct wire placement.
