BFL13
Oct 05, 2015Explorer II
KJINTF wrote:
One more try - This picture should clear things up
Why some folks says things that are WRONG is beyond my comprehension
As can be clearly seen the fuses are connected in parallel and are ONLY on the "+" output
Thank you!!!! Yes, I did know it was on the pos only, but could not figure out how the two fuses were wired up.
Any opinion why a single fuse on the output wire away from the unit would not do the same job, or is the location of that fuse circuit within the rest of the schematic what counts for reverse polarity protection (whereas the normal fuse farther out on the pos wire is to "protect the wire")?
Yes, I am using the 7355 as a shore power-only converter in the truck camper. For off-grid charging I will use a Vector 35 amp smart charger if the solar can't keep up.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
