BFL13
Oct 05, 2015Explorer II
Thanks again. I wondered if those sense wires at either end of the RP fuses group had something to do with the RP protection.
Not clear why the single fuse outside the unit should be close to the converter instead of near the battery where you would get more of the wire protected. I do want to protect both the converter from reverse polarity and the wire as usual with a "battery fuse" Or do I need two fuses, one at each end of the wire? The wire will be about three feet long in this case, but what if it were twenty feet long?
RJ, yes, I now understand your post with the single fuse being in series. I got off track when you said "they" and was still thinking about the two 30s (which are in parallel). All clear now! :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
