MEXICOWANDERER
Oct 05, 2015Explorer
In haste I forgot to add that the both legs fuses are what should be used and not necessarily what are used. Most high end inverters use a permanent FUSIBLE LINK as a last resort protector. Sorry for my lapse. I have seen a Trace 5548 burned to the ground with the chassis ground wire fried from using a positive only fuse not protecting reverse input. Started a fire that burned down a shed.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
