Chris_Bryant
Oct 05, 2015Explorer II
Dutch_12078 wrote:
Even though it makes no sense from a cost standpoint to parallel fuses when a larger single fuse costs about the same, I bow to your superior knowledge and experience...
The common ATC fuses they use are not available any larger than 40 amps, which is too small for this application. The maxi fuse is quite a bit larger, and would present layout problems.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
