Dutch_12078
Oct 05, 2015Explorer III
Chris Bryant wrote:Dutch_12078 wrote:
Even though it makes no sense from a cost standpoint to parallel fuses when a larger single fuse costs about the same, I bow to your superior knowledge and experience...
The common ATC fuses they use are not available any larger than 40 amps, which is too small for this application. The maxi fuse is quite a bit larger, and would present layout problems.
Ok, I can understand that logic. The converters I'm used to dealing with (industrial, not RV use) commonly use maxi's in the small under 100 amp sizes.
