Salvo
Oct 06, 2015Explorer
You're correct. If reversed polarity, +12V battery goes to the ground of the secondary winding center tap, through the 4 diodes and the fuses, and back to battery ground. That should blow the fuses.
Chris Bryant wrote:
If you look at the schematic that KJINTF posted, other than the small filter capacitors and inductors, the last thing in the circuit is the diodes.
