BFL13's avatar
BFL13
Explorer II
Oct 04, 2015
Reverse Polarity Fuses Circuit Question
Ok fellow scientists :) What is so special about the reverse polarity fuse circuit in a converter compared with just having a fuse on the positive output wire?
I yanked the 7355 from the trailer to put in the truck camper, and that means it is now like a portable charger with 120v input (no neg wire though, just hot and neutral with a 7355) and pos and neg DC wires output.
Its two 30 amp reverse polarity fuses are still on the DC fuse panel back in the trailer, doing nothing now. Somebody said here a while back that each 30 did half so it was like 60 (on the 55 amp converter)
So how can I wire up a set of reverse polarity fuses for the loose 7355, or can I just depend on a 60 amp fuse on the positive wire?
(AFAIK, I am also supposed to run a chassis ground wire for it now that it is no longer in its original power centre, same as you would for a deck mount.)
Thanks.
  • I am still confused about series and parallel here. What is wired to which end of what? Two 30 amp fuses and one output pos wire. Now what do you do? Thanks.
  • I wondered why my new little 150 watt inverter had one 40 amp fuse inside the box, which blowed when I crossed polarity. I couldn't find a 40 amp fuse so used a 30. Seems to work, as I overloaded it several times since, and the 30 amp holds.
    Good to know they are in series w/ the pos output, always wondered about that.
  • Sorry I got confused there as to what is in series and what is in parallel. Is the pos wire split with a 30 on each leg then rejoined?
  • Yes the reverse polarity fuses are in series with the output of the converter
    Are you actually using a single voltage Parallax converter????????
    Two lower cost fuses are less expensive and easier to install
    Nothing more than a matter of cost for the manufacturer
    IMHO A parallel connection of a fuse is STUPID at best nothing more than a cost saving that the comsumer pays for sooner or later
  • Not getting the info requested so far.
    I want to know if there is some special way you have to wire up a couple of 30s however they do it in a converter or over at the DC fuse panel, instead of using a 60 farther out on the pos wire.
    Why do they use two instead of just one big one?
    My PowerMax 100amper uses four 40s while the PowerMax 55 amper uses two 40s. The 7355 uses two 30s but they are over on the fuse panel.
  • Hi doug,
    Reverse polarity fuses worked for a shop that managed to put one of the twelve volt jars in series with the others--presenting 24 volts to the converter.
    They also worked when I was attempting to do double conversion with my Magnum inverter. Double conversion with my old Cobra MSW was no problem. I don't understand why there was a difference.
    BFL13, yes fuse on the positive but use what mex has wisely recommended.
  • Use T rated ultra fast reaction fuses. Refer to good inverter reading like Outback or Magnum for an in-depth explanation of their purpose and function. I like inverter and charger products that scream polarity orientation via color. I.e. red wire to red terminal.
  • The purpose is to prevent destroying the Power converter when you hook up the positive and Negative cables at the battery in reverse. It rarely works. But, sometimes it does. Doug
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
