SCVJeff
Oct 28, 2014Explorer
WyoTraveler wrote:Depends. I did allot of work with this problem about 2 years ago. Depending on the LED, carefully placed caps, tightly twisting the power leads both in and out of the regulator can make a significant difference, or none at all. If it were me I would replace the LED's with ones without regulators, then find a common feed to all the lighting and install a single regulator. Even the cheap ones on eBay are way better filtered than any LED out there.
Wonder if a capacitor and Rf choke would across the led 12 volts.
I'm running a 12W LED scare light wired for 9V full bright through a regulator and a dimmer, and there is zero RFI from it.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
