AnEv942
Nov 11, 2014Nomad
SCVJeff wrote:
... I did allot of work with this problem about 2 years ago. Depending on the LED, carefully placed caps, tightly twisting the power leads both in and out of the regulator can make a significant difference, or none at all...
Well more like 4 1/2 years ago... This thread, SVCJeff had a considerable of input when I originally switched to leds & discovered interference, though mostly on FM radio. Only the light closest & under the antenna would cause slight TV interference. On the radio was also a proximity thing, closer the light that was on, greater the interference.
My fix and still working was simple caps in the housings. (though from what I could gather shoudnt have worked).
Couple of weeks old but thought worth linking Jeffs previous input on problem.
Mark
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
