Gdetrailer
Oct 02, 2013Explorer III
jalichty wrote:
Don't know if this is the place to put this, but if not, I'm sure the moderator will put it in the proper place. We bought an ATV trailer a while ago and it has a deck of plywood treated with some type of waterproofing material that is starting, already, to wear off. Was wondering if anybody has used Rhino Liner or something like it to treat wood decking? Wonder if it's even plausible? Any replies would be appreciated.Moved to Tech Issues forum from Towing.
If the plywood decking is outdoor "pressure treated" you do not need to "seal" it.
If is plain plywood, then simply paint it with a good quality outdoor rated paint. Much cheaper than any "bed liner" and will last many years before needing repainted.
I had a 4x8 utility trailer for nearly 20 yrs, I had to replace the non pressure treated plywood decking after 15 yrs. The original decking was simply painted with oil based paint from Tractor Supply.
I replaced the original plywood decking with PRESSURE TREATED plywood and gave it a coat of Tractor Supply paint after a couple of years. Sold the trailer 5 yrs after I replaced the decking and the plywood looked as good as new then.
A gallon of Tractor Supply paint costs $25 (hint, add in the hardner for this paint and it will give it some shine plus last longer)or so now days vs a couple of hundred for bed liner paint...
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
