dougrainer
Jul 24, 2016Nomad
So, you state that the OLD AC and the NEW AC, the fan has a problem? You stated the OLD AC did not blow cold air. IF the fan did not run, how did you know you did not have cold air?????? But, since the unit is NEW, and you state you still have a non functioning FAN, The ONLY thing it can be is either the Control Circuit board or the connections to that 6 pin multiplug on that control board. It could be the wall tstat, but it depends on what MODEL of Dometic Tstat you have. Also, do you HAVE a Dometic wall tstat or have you or someone else installed a residential type tstat? Doug
