Sam_Spade
Jul 24, 2016Explorer
dlplaia wrote:
Nope, the fan did not come on in fan only mode.
Well then there are 3 possible causes:
Bad stat
Bad wiring
Bad fan
You need to know a little bit about exactly how things work in order to be able to do a couple of simple tests to see where the problem IS. Someone here can, no doubt, help with that. That is not me.
If you replaced the entire air handler including the fan, then that pretty much eliminates a bad fan. Might not eliminate a power problem going to it though.
