SJ-Chris's avatar
SJ-Chris
Explorer II
Jul 17, 2018
roof AC issue, could this be causing it??
Greetings all!
I'm having an issue with one of my RVs and the roof AC (RVP RV Products 8000 series). This is on a 2008 Four Winds 31P Class C RV. I was parked at my house and plugged in via a 100 foot extension cord connected to a 20amp outlet in my garage. I don't think there is anything else connected to this outlet in my garage (it is a dedicated outlet for a whole house vacuum). The RV shore power line is a 30amp line/connector. I have a simple plug connector that allows me to plug in the 30amp plug into a standard 120v extension cord.
The 100 foot extension cord is a fairly standard gauge but seems lighter duty (thinner compared to some of my other heavy duty extension cords) and it is pretty old. And of course the 30amp plug on the RV has another ~30 feet as well. When plugged in to my home (aka shore power from a home outlet) the roof AC seems to struggle a bit. It will run for several minutes on High and seem normal, but then it will suddenly drop down to Low (perhaps even below what I would expect if I set it to "Low" on the thermostat) and then after 20-30 seconds it might jump back up to full force (High). It has also tripped the AC breaker on my converter box (Parallax) a few times if I have it running for more than 10-20 minutes.
I just did an experiment...I needed to drive to dump my RV waste tanks and run a few errands so I turned on the generator (4000w Onan) and ran the roof AC the entire time (for about 1.5 hours) off the generator. I had the roof AC set to High. It seemed to run perfectly the entire time. It didn't once struggle or drop down to a lower speed and it didn't trip the AC circuit breaker in my converter panel. I would consider it as having functioned completely as expected. That got me to thinking....could it be that my long 100 foot, older light-weight extension cord is causing my issue? Could there be some sort of voltage drop happening over that long distance and it is causing my roof AC to not have enough voltage/amperage? Do my symptoms seem to point in that direction? I just felt the extension cord and it even felt a little warm (could this be indicating that it is not heavy enough gauge for the load??).
Let me know your thoughts. I want to make sure my roof AC is functioning properly of course, and I can always bring it to an RV mechanic to have them take a look, but people on here are always incredibly wise and helpful so I thought I'd check with the RV.net community first to see if I can get some pointers/suggestions.
I do have a heavier duty extension cord and I think I'm going to give that a try to see if I have the same symptoms or not.
Thanks in advance! Let me know your thoughts.
Chris
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
