- drsteveExplorer
Yochief1948 wrote:
The little box is sealed and no magnet is visible it is the reed switch, they sell ones that look like it on the internet.
The switch is supposed to come to rest near a magnet, which is what activates it. Is that magnet near the switch when the antenna is down?
You can test your existing switch using a magnet. Put it next to the switch and if your warning light goes out, the switch is working. - Yochief1948ExplorerThe little box is sealed and no magnet is visible it is the reed switch, they sell ones that look like it on the internet.
- Yochief1948ExplorerSee below post
- drsteveExplorer
Yochief1948 wrote:
Found the reed switch on the antenna it’s blue 2” square with 2 white wires comming out, only thing on switch is ASSEMtech, found some online but they have different voltages etc, does anyone know which one I need, thanks
Is the switch the problem, or is the magnet missing, as Chris suggested? - Yochief1948ExplorerFound the reed switch on the antenna it’s blue 2” square with 2 white wires comming out, only thing on switch is ASSEMtech, found some online but they have different voltages etc, does anyone know which one I need, thanks
- Big_KatunaExplorer IIMy ole 97 Vacationer surprisingly had a mercury switch on it.
And strangely, the antenna was over the bedroom. - Yochief1948ExplorerOk thanks, will check it out when I go to MH tomorrow
- Chris_BryantExplorer II
- wolfe10ExplorerMany use the same switches used for home window alarm systems.
Easy for water to get in them and short the contact. Go up and pull it off and go to any alarm/box store for a replacement. Under $10. - Yochief1948ExplorerNot sure what I’d be looking for, is their a picture of this reed switch, thanks
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
