dougrainer
Aug 17, 2013Nomad
The Dicor will "dry" out the plastic skylight. Fleetwood Towables (before they shut down) had a TSB about this problem and you had to use Alpha. What happens is the flange where you screw it down dries out and weather cracks and then leaks from the Dicor contac. It depends on what the replacement skylight covers are made of if you can use Dicor or Alpha. Alpha will work on all roof materials. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
