dougrainer
May 27, 2016Nomad
CA Traveler wrote:SolidAxleDurango wrote:To bad he didn't insert some dye as a future leak would then be very easy to detect.
Nowhere did any line exhibit the typical sign of leakage... Dirty or oily residue....
If it was low/empty, YOU HAVE A LEAK. They only hold 1 lb of coolant, so it will not take long for your fixed AC to stop blowing cold. IF he used a clamp on line tap, then you will have another leak in the next year. Line Taps compress the copper line and will eventually leak. They are not meant as a permanent fill valve. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
