westend
Oct 31, 2013Explorer
ScottnSherrie wrote:Don't keep the old pads unless you want to do all of this again. When the pads see that kind of heat for the times assumed, you can be sure they will chip and fail at some point. Also, if you've had a caliper stick, I'd assume the rotor is beyond service.
My brakes look a lot like ones of the pics in the eBay post you linked to.
I think I have settled on replacing all hoses (front and rear), replacing the caliper that overheated and deglazing the pads from the left rear. I know pads aren't crazy expensive but they have tons of material left.
The one part of this job that I am not looking forward to is bleeding the brakes. The reservoir is in a crazy place. The only way to get to it is to crawl under the beast and sit on the ground between the left front tire and the frame. Thank goodness I'm still a skinny guy.
Ya, bleeding brakes can be terrible but have a friend handy and take your time. The pedal operator can operate a reservoir filler in between pedal operation. A funnel with attached hose will be your friend.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
