enblethen
Nov 01, 2013Nomad
I would take the other side off the mount, inspect it, clean and lube it good.
Just a little more labor but may save issues.
Make sure you get good brake lube. use plenty on the slide areas and the wedge keeper.
I used a small Dremel style grinder to clean the slide areas.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
