ScottnSherrie
Nov 01, 2013Explorer
enblethen wrote:
I would take the other side off the mount, inspect it, clean and lube it good.
Just a little more labor but may save issues.
Make sure you get good brake lube. use plenty on the slide areas and the wedge keeper.
I used a small Dremel style grinder to clean the slide areas.
Yep. Left that out of the published plan. I will be removing all the calipers for inspection, cleaning and greasing. If front pads need replaced, that will get done as well.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
