ScottnSherrie
Nov 01, 2013Explorer
j-d wrote:
....That's a $4 Front Caliper Kit from ACDelco. As the article notes, most if not all the matchup is done by Piston Diameter. Your calipers are probably Dual Piston. Might take two front caliper kits for a Chevelle to fix one of your rear calipers. Quote from the article....
Are you saying a Chevelle caliper seal is the right size for the dual 2.5 inch pistons in the Dayton Walther brake calipers on my John Deere chassis? I would gladly take the time to rebuild all the calipers if I could find seals that are the right size.
I Googled for '2.5 inch brake caliper seal' and didn't get any promising hits.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
