MrWizard
Apr 16, 2017Moderator
LESS Ahr for the same PHYSICAL SIZE (IE takes MORE AGM batteries to equal Flooded Lead Acid).
Not in all cases
Spiral wound optima batteries fit your description
Standard agm car jars are on a par in weigh versus amp hrs with more cca as flooded
My Telco AGM batteries are in between, the weight versus amps of flooded GC versus car jar batteries
My AGMs weigh more than gc and offer a few ampHrs more rating per pair
200# 270 amp hrs at 8 hr cycle rate
versus GC pair 130# 230 amp hrs 20 hr cycle rate, what is the 8 hr rate of a pair of gc
I have to double check, but I think the 20 hr rate of my AGMs was 316 amp hrs per pair
Besides we are off topic, this was not asked to be a comparison discussion
That has happen way to many times
The question, did you get one of the items listed ?
Are you happy
The I don't understand all the fuss
Is not worth the money, I'm sticking to fla
All verge on trolling
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
