map40
Sep 08, 2014Explorer
Rubber roof loose
I'm in the process of applying bed liner to my roof and noticed the roof is loose in some areas. I'm planning to cut a small hole and inject some epoxy to re-glue it. Opinions?
westend wrote:
Does Grizzly Grip contain any hydrocarbon solvents? If so, that may be why you are seeing contraction of the EPDM. The solvents will react with a rubber roof.
